- Mute
- Permalink
- Report
Thanks Chandra for your reply.
I finally discoverd that the problem was on the Browser names.
What happens with place ilogic component is that the name on the browser is always the same even thought you replace the part. Since I did not realize it, I thought that the part was not replaced, but in fact, behin the same browser name, there was a new file name.
This situation is quite counter intuitive, when you york with regular assemblies, and need some background knowledge.
Other curious aspect is that the Copy Tab in the iproperties window of the part, appears only when you access it from the assembly environtment. I undestand now that this is so, because the fuction of this name is the control of the master occurrence in the assembly, and that is the base for the ilogic rules keep working, when you rename a file.
Thank you very much for your time and contribution.
