- Mute
- Permalink
- Report
Unless you want to get into a bunch of Trigomometry math, I suggest you use sketches and sketch-based patterns to control the pattern, instead of trying to pattern an already existing solid body. Or you can use a "Sketch Driven" pattern to pattern the first solid body. Either way, instead of your pattern being constained to a rectangular pattern, you can use a dimensioned construction line to set your angle, then create a point (or your step profile) on it, then pattern that point (or step profile) along the construction line. When creating this sketch pattern, use the Quantity parameter and the Spacing parameter within it. Then you can use that sketch to either extrude your steps (if you used the profile sketches), or base your "Sketch Driven" pattern by (if you used the points).
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES"
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
- Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
- MessageBox, InputBox, and InputListBox Size & Format Options Click Here
- Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
- Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
- Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
- Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
- SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
- Create DocumentSubTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
