- Mute
- Permalink
- Report
Here is a simple example of the code you can use within a local iLogic rule to limit the value of a parameter named "Overall_Height" to a value between 12 and 240. If you enter a number higher it tells you, then sets the value to the maximum limit. If you enter a value to low, it tells you, then sets the value to the minimum limit.
If Overall_Height > 240 Then
MsgBox("That Overall Height is too tall. Please enter a value between 12 and 240.", vbOKOnly, "TOO TALL")
Overall_Height = 240
ElseIf Overall_Height < 12 Then
MsgBox("That Overall Height is too short. Please enter a value between 12 and 240.", vbOKOnly, "TOO SHORT")
Overall_Height = 12
End If
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES"
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
- Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
- MessageBox, InputBox, and InputListBox Size & Format Options Click Here
- Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
- Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
- Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
- Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
- SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
- Create DocumentSubTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
