mcgyvr
in reply to: mdavis22569
Lets see if this technique works for your situation...
I'm assuming that those are 2 different parts in an assembly.. (I'm going to call them knurled cap and housing because well I want to :beaming_face_with_smiling_eyes: )
Simply link in the parameter of the knurled caps height from its part file and the parameter of the housing height from its part file into the assembly... Then you have the distance you want as the sum of those 2..
Steps as follows...
In the assembly go to the parameters dialog (fx button) and press the link button at the bottom..
Find the knurled cap and link the height of that into the assembly..
Repeat for the housing..
Now you have those parameters linked and usable in your assembly.. Should either of those change then the assembly will know and update accordingly...
