GoranBe
2184 Views, 22 Replies
Distance between two faces in assy as a parameter
Hello
What is the easiest way to get distance between two faces, store it into some user parameter and have the value updated if the distance changes. From experience I know that if I Measure the parameter value it will not update, if the distance changes. I tried to create dimension annotation in model, but I am not aware of how to use it's value as a parameter. In short, I'd like to have 47,00 mm dimension value from the picture below stored in the (named) parameter and updated, if it changes due to any reason - housing height change, constrains change etc...
Thanks for your ideas
Goran
