Hi @t.brosens
I think you might want to do a replace component with the long one for a shorter one and then pattern the shorter one.  if you can post some simple examples (they can just be basic blocks) that might help others provide some example to get you started, be sure to mention which version of Inventor you're using.
here is a link to a past post that shows one method of how to "fill" the pattern in plus a remainder, in case that helps:
https://forums.autodesk.com/t5/inventor-forum/i-logic-assembly-pattern/m-p/3763544#M459819
I hope this helps.
Curtis
