J_Dumont
in reply to: rhasell
Good morning.
Thank you for your response.
In testing your code it seems to work as long as I don't have a sorting done by selecting any particular column. See the attached image. The only way I am able to clear the predefined sort is to use Sort and specify any column. See attached Screencast. Once the predefined Sort is cleared the code works properly.
https://autode.sk/2JuuIyl
