03-30-2020
11:44 PM
- Mute
- Permalink
- Report
03-30-2020
11:44 PM
You can also update the code a bit to handle the broken link scenario:
Sub Main()
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "")
Dim PrFtrNm As String=""
Dim oNBND As NativeBrowserNodeDefinition=ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oFace.SurfaceBody.CreatedByFeature)
If oNBND.NativeObject.Type=ObjectTypeEnum.kReferenceFeatureObject Then
If oNBND.NativeObject.ReferenceComponent Is Nothing Then
Dim oRefComp As ReferenceComponent
Dim oRefFeature As ReferenceFeature
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
For Each oRefComp In oDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents
PrFtrNm = getLabel(oNBND.NativeObject,oRefComp)
If PrFtrNm <> "" Then
GoTo findLabel
End If
Next
' For Each oRefComp In oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
' PrFtrNm = getLabel(oNBND.NativeObject,oRefComp)
' If PrFtrNm <> "" Then
' GoTo findLabel
' End If
' Next
Else
PrFtrNm = oNBND.NativeObject.ReferenceComponent.ReferencedDocumentDescriptor.DisplayName ' "With" exception failure if link to derived (reference) component is suppressed or broken.
End If
findLabel :
Else
PrFtrNm=oNBND.Label
End If
MsgBox(PrFtrNm, , "PrFtrNm")
End Sub
Function getLabel(oParentRefFeature As ReferenceFeature, oRefComp As ReferenceComponent) As String
For Each oRefFeature In oRefComp.ReferenceFeatures
If oParentRefFeature Is oRefFeature Then
If oRefComp.ReferencedDocumentDescriptor Is Nothing Then
getLabel = oRefComp.Name
Exit For
Else
getLabel = oRefComp.ReferencedDocumentDescriptor.DisplayName
Exit For
End If
End If
Next
End Function
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
