03-26-2020
02:08 PM
- Mute
- Permalink
- Report
03-26-2020
02:08 PM
This is probably something very basic, but I would like to know the reason why the following does not work:
Sub Main()
Dim oDoc as Inventor.Document = ThisApplication.ActiveDocument
Dim sDispName as String = oDoc.DisplayName
sDispName = "doc123"
End Sub
Whereas the following works fine:
Sub Main()
oDoc.DisplayName = "doc123"
End Sub
I'm guessing it has something to do with not referencing the object or something, but would like to be sure. If this is the case, when would I need to make sure I set a reference to an object with the various properties in the API? Is it only if the type of the property is not a built-in VB data type?
