johnsonshiue
Hi Bianca,
I don't think you can link a top-level assembly parameter to a subassembly. This can introduce cyclic relationship. However, you can drive all parameters from any level at the top-level assembly. For example, you have a parameter called "Top_Length" at the top level. And, you want it to drive "Sub_Length" at the sub level. You can simply write an iLogic rule to capture "Sub_Length" and the equate it to "Top_Length."
Would it work for you?
Many thanks!
Software Test Engineer
