552 Views, 2 Replies
Ilogic shared costum parameters
Is it possible to share your custom parameters from you main assembly with your sub-assembly's?
The costum parameters are inportant for the design and all of the sub-assembly's have to change when the Value of the parameter is changed.
If there is an other option to share parameters and use them in multiple parts/assembly's, that's also an option.
I am looking forward to hearing from you.
