k14348
in reply to: k14348
   Can anybody correct this code to open the partDocument. If "=" sign not there.
Option Explicit
Sub DescriptCheck()
    Dim oApp As Application
    Set oApp = ThisApplication
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = oApp.ActiveDocument
    Dim oPartDoc As PartDocument
    Dim oProp As Property
    For Each oPartDoc In oAsmDoc.AllReferencedDocuments
    Set oProp = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
    Dim oVal As Variant
    oVal = oProp.Expression
    MsgBox (oVal)
    If Left(oVal, 1) = "=" Then
    MsgBox ("yes")
    Else
    'oPartDoc.Open I need this line to open the doc
    End If
    Next
End Sub
