- Mute
- Permalink
- Report
I have a main assembly with 10 No. of parts. I would like to check all 10 Parts description starts with = or not. If Description not starts with = sign then i need that file name list.
Karth
- Mute
- Permalink
- Report
you can try this.
Dim notLinkedList As String = ""
Dim AssDoc As AssemblyDocument = ThisDoc.Document
For Each doc As Document In AssDoc.ReferencedDocuments
Dim oPropSets As PropertySets = doc.PropertySets
Dim oPropSet As PropertySet = oPropSets.Item("Design Tracking Properties")
Dim oPartNumiProp As Inventor.Property = oPropSet.Item("Description")
If (oPartNumiProp.Expression = Nothing) Then
notLinkedList = notLinkedList + doc.FullFileName + System.Environment.NewLine
Continue For
End If
If (oPartNumiProp.Expression.StartsWith("=") = False) Then
End If
Next
MsgBox(notLinkedList)
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
Thanks for your reply. As i know only vba i expect this coding in vba. Thanks for understanding.
Karth
- Mute
- Permalink
- Report
Can anybody correct this code to open the partDocument. If "=" sign not there.
Option Explicit
Sub DescriptCheck()
Dim oApp As Application
Set oApp = ThisApplication
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = oApp.ActiveDocument
Dim oPartDoc As PartDocument
Dim oProp As Property
For Each oPartDoc In oAsmDoc.AllReferencedDocuments
Set oProp = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
Dim oVal As Variant
oVal = oProp.Expression
MsgBox (oVal)
If Left(oVal, 1) = "=" Then
MsgBox ("yes")
Else
'oPartDoc.Open I need this line to open the doc
End If
Next
End Sub
- Mute
- Permalink
- Report
I think the line you're looking for is:
Call ThisApplication.Documents.Open(oPartDoc.FullFileName, True)
'Or in your case
Call oApp.Documents.Open(oPartDoc.FullFileName, True)
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES"
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
- Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
- MessageBox, InputBox, and InputListBox Size & Format Options Click Here
- Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
- Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
- Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
- Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
- SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
