in reply to: WCrihfield
Yes sorry,
I'm trying to make the part number the same as that shown in the occurrence name in the iProperties options.
I have an assembly all made, where I've used the frame generator tool, but the part number shows the 'standard-section-length'. Therefore I need to run the iLogic command in the assembly when using the generator, instead of manually changing the save file name or the part number.
I have not made a custom property as I thought that the occurrence section in the iProperties would already be built into 'code' ready to use.
I also would change the assemblies part number to a bespoke format instead of its saved file name.
