WCrihfield
Can you be more specific / informational about what you are trying to do?
Do you have a main assembly open, and trying to change a ComponentOccurrence's "Part Number" property to that same Occurrence's (Occurrence.Name)?
Are you trying to change your main assembly "Part Number" property to one of the assembly's ComponentOccurrence names?
Are you trying to change a BOMRow Item Number, within a main assembly, to a ComponentOccurrence name instead of an Integer?
Have you already created a custom PropertySet named "Occurrence", within the main assembly, and added a property named "Name" to it, that you're wanting to use?
Wesley Crihfield
(Not an Autodesk Employee)
