- Mute
- Permalink
- Report
I'd like to know if it possible to get DisplayName of the top-most BrowserNode parent to the given Face when it is about DerivedAssembly with link suppressed.
As a test sample I'm using Switch Mold_Combined CR1.ipt (one of generic sample files see folder \Models\Mold Design\Switch\Switch Mold\).
I'm using this iLogic code:
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "")
Dim PrFtrNm As String=""
Dim oNBND As NativeBrowserNodeDefinition=ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oFace.SurfaceBody.CreatedByFeature)
If oNBND.NativeObject.Type=ObjectTypeEnum.kReferenceFeatureObject Then
PrFtrNm=oNBND.NativeObject.ReferenceComponent.ReferencedDocumentDescriptor.DisplayName ' "With" exception failure if link to derived (reference) component is suppressed or broken.
Else
PrFtrNm=oNBND.Label
End If
MsgBox(PrFtrNm,,"PrFtrNm")
When I pick one of that faces (for example the one highlighted red on the screenshot):
I get exactly what i need:
But if I try to repeat this after suppress link with Base (Derrived Assembly) component I get error "Object Variable or With block Variable Not Set" instead.
Hope to get some workaround for this case...
PS:
Sorry I dont know how to choose oFace using one of its identifiers
TransientKey:
43852
or
GUID:
{19A3A58F-597A-1506-FD16-70F14FA4D916}
Please vote for Inventor-Idea Text Search within Option Names
