Maxim-CADman77
525 Views, 4 Replies
DisplayName of BrowserNode parent to the Face (DerrivedAssy with SuppressedLink)
I'd like to know if it possible to get DisplayName of the top-most BrowserNode parent to the given Face when it is about DerivedAssembly with link suppressed.
As a test sample I'm using Switch Mold_Combined CR1.ipt (one of generic sample files see folder \Models\Mold Design\Switch\Switch Mold\).
I'm using this iLogic code:
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "")
Dim PrFtrNm As String=""
Dim oNBND As NativeBrowserNodeDefinition=ThisDoc.Document.BrowserPanes.GetNativeBrowserNodeDefinition(oFace.SurfaceBody.CreatedByFeature)
If oNBND.NativeObject.Type=ObjectTypeEnum.kReferenceFeatureObject Then
	PrFtrNm=oNBND.NativeObject.ReferenceComponent.ReferencedDocumentDescriptor.DisplayName ' "With" exception failure if link to derived (reference) component is suppressed or broken.
Else
	PrFtrNm=oNBND.Label
End If
MsgBox(PrFtrNm,,"PrFtrNm")
When I pick one of that faces (for example the one highlighted red on the screenshot):
I get exactly what i need:
But if I try to repeat this after suppress link with Base (Derrived Assembly) component I get error "Object Variable or With block Variable Not Set" instead.
Hope to get some workaround for this case...
PS:
Sorry I dont know how to choose oFace using one of its identifiers
TransientKey:
43852
   or
GUID:
{19A3A58F-597A-1506-FD16-70F14FA4D916}
Please vote for Inventor-Idea Text Search within Option Names
YuhanZhang
in reply to: Maxim-CADman77
Seems there is a problem that when the derived assembly is suppressed the ReferenceFeature.ReferenceComponent returns Nothing here. I updated the iLogic code to workaround it, you can try if it works well there:
Sub Main()
	If oNBND.NativeObject.ReferenceComponent Is Nothing Then
		Dim oRefComp As ReferenceComponent
		Dim oRefFeature As ReferenceFeature
		Dim oDoc As PartDocument
		oDoc = ThisDoc.Document
		For Each oRefComp In oDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents
			PrFtrNm = getLabel(oNBND.NativeObject,oRefComp)
			If PrFtrNm <> "" Then
				GoTo findLabel
			End If
		Next
'		For Each oRefComp In oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
'			PrFtrNm = getLabel(oNBND.NativeObject,oRefComp)
'			If PrFtrNm <> "" Then
'				GoTo findLabel
'			End If
'		Next
	Else
		PrFtrNm = oNBND.NativeObject.ReferenceComponent.ReferencedDocumentDescriptor.DisplayName ' "With" exception failure if link to derived (reference) component is suppressed or broken.
	End If
findLabel :
Else
	PrFtrNm=oNBND.Label
End If
MsgBox(PrFtrNm, , "PrFtrNm")
End Sub
Function getLabel(oParentRefFeature As ReferenceFeature,oRefComp As ReferenceComponent) As String
For Each oRefFeature In oRefComp.ReferenceFeatures
		If oParentRefFeature Is oRefFeature Then
			getLabel = oRefComp.ReferencedDocumentDescriptor.DisplayName
			Exit For
		End If
Next
End Function
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Maxim-CADman77
in reply to: YuhanZhang
I can accept - this does the trick for the suppressed link.
But what if the link is broken?
Could top-most node still be found in that case somehow?
As far as Inventor understands relationship (I meant browser tree) it should be possible to track feature to the browser-node of TopNode, right?
YuhanZhang
You can also update the code a bit to handle the broken link scenario:
Sub Main()
				GoTo findLabel
			End If
		Next
'				GoTo findLabel
'			End If
'		Next
	Else
	End If
findLabel :
Else
	PrFtrNm=oNBND.Label
End If
End Sub
Function getLabel(oParentRefFeature As ReferenceFeature, oRefComp As ReferenceComponent) As String
            If oRefComp.ReferencedDocumentDescriptor Is Nothing Then
                getLabel = oRefComp.Name
                Exit For
            Else
                Exit For
            End If
        End If
Next
End Function
Rocky Zhang
Inventor API PD
Autodesk, Inc.
