03-17-2020
04:27 AM
- Mute
- Permalink
- Report
03-17-2020
04:27 AM
If you problem is solved, you can click the "Accept As Solution" on your last response, to close out this issue.
Tip: Using the Design View Representations is almost always preffered over using Level Of Detail Representations.
Level Of Detail Representations are mostly only used to save memory (RAM) when working with large assemblies.
Wesley Crihfield
(Not an Autodesk Employee)
