03-07-2020
11:57 PM
- Mute
- Permalink
- Report
03-07-2020
11:57 PM
Sub Main Add_Parameters End Sub Sub Add_Parameters Dim doc As PartDocument doc = ThisDoc.Document Dim pcd As PartComponentDefinition pcd = doc.ComponentDefinition If ThisApplication.ActiveDocumentType = kPartDocumentObject Then MultiValue.UpdateAfterChange = True MultiValue.SetValueOptions(True) 'example to only setmulivalue j = 10 For i = 1 To j : Try : If Parameter("k_flange_N" & i) <> -100 Then : End If : Catch : doc.ComponentDefinition.Parameters.UserParameters.AddByExpression("k_flange_N" & i, 1, "mm") : End Try : Next For i = 1 To j : MultiValue.SetList("k_flange_N" & i, -1, 0, 1) : Next 'example to setmulivalue and allow custom value j = 20 index_no = 2 For i = 1 To j : Try : If Parameter("set_N" & i) <> -100 Then : End If : Catch : doc.ComponentDefinition.Parameters.UserParameters.AddByExpression("set_N" & i, 0, "mm") : End Try : Next For i = 1 To j MultiValue.SetList("set_N" & i, -2, -1, 0, 1) Set_Attributes_To_Mulitivalue("set_N" & i) 'set default index value Dim oParam1 As UserParameter oParam1 = ThisDoc.Document.componentdefinition.parameters.item("set_N" & i) oParam1.ExpressionList.SetExpressionList(oParam1.ExpressionList.GetExpressionList(), True, index_no) Next RuleParametersOutput() InventorVb.DocumentUpdate() End If End Sub Function Set_Attributes_To_Mulitivalue(PARAM_NAME As String) Dim doc As PartDocument doc = ThisDoc.Document Dim pcd As PartComponentDefinition pcd = doc.ComponentDefinition Try Dim paramAttribSet As AttributeSet pcd.Parameters.UserParameters.Item(PARAM_NAME).AttributeSets.Add("com.autodesk.inventor.ParameterAttributes") paramAttribSet = pcd.Parameters.UserParameters.Item(PARAM_NAME).AttributeSets.Item("com.autodesk.inventor.ParameterAttributes") Try paramAttribSet.Add("AllowCustomValue", ValueTypeEnum.kIntegerType, 0) Catch ex As Exception End Try paramAttribSet.Item("AllowCustomValue").Value = 1 Catch End Try End Function
