tonychristman4915
2759 Views, 7 Replies
iLogic drawing view controls in drawing files
Hello all,
I'm looking for how to use inventor iLogic to activate and deactivate the "Definition in Base View" option for drawing views. This is found by double clicking on a drawing view and selecting the "Display Options" tab.
I have a drawing file that uses an iLogic rule to activate and place section views but I want to give the option to our engineering staff to change the locations of the section views, then run a rule that hides all the arrows that clog up the Base view without having to click on every view manually.
The closest post I've found was this one: http://forums.autodesk.com/t5/inventor-general-discussion/ilogic-make-drawing-view-shaded/td-p/37586... that discussed how to use iLogic to change the view style, however I haven't discovered how to control the "Definiton in Base View" option yet.
Thanks!
