03-05-2020
07:53 AM
- Mute
- Permalink
- Report
03-05-2020
07:53 AM
I got a workaround to my problem by using ThisApplication.CommandManager..ControlDefinitions.Item("AppFileSaveAsCmd") to run the "SaveAs" command instead of ThisDoc.Document.SaveAs()
The idea was to make a "Smart SaveAs" rule in a drawing document which would auto-populate the saveas dialog with PartNumber - RefModelFilename.idw to save time when saving a lot of drawings.
As a workaround, my code uses the clipboard instead:
Dim openDoc As Document openDoc = ThisDoc.Document 'Look at the model file referenced in the open document Dim docFile As Document If ThisDoc.ModelDocument IsNot Nothing Then docFile = ThisDoc.ModelDocument Else MessageBox.Show("This drawing has no model reference", "iLogic") Return End If 'format model file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'remove Extension Dim docFNameSimple As String docFNameSimple = Left(docFName, Len(docFName) - 4) ModelPartNumber = iProperties.Value(docFName, "Project", "Part Number") 'ModelDescription = StrConv(iProperties.Value(docFName, "Project", "Description"), VbStrConv.ProperCase)'ModelTitle = StrConv(iProperties.Value(docFName, "Summary", "Title"), VbStrConv.ProperCase)'ModelSubject = StrConv(iProperties.Value(docFName, "Summary", "Subject"), VbStrConv.ProperCase) AutoFilename = ModelPartNumber & " - " & docFNameSimple Clipboard.SetText(AutoFilename) ThisApplication.UserInterfaceManager.UserInteractionDisabled = False Dim oCommandMgr As CommandManager oCommandMgr = ThisApplication.CommandManager Dim oDef As ControlDefinition oDef = oCommandMgr.ControlDefinitions.Item("AppFileSaveAsCmd") oDef.Execute2(False)
Still it would be nice to know if there is a way to get the last saved file location in iLogic.
