sam
in reply to: chandra.shekar.g
Hi @chandra.shekar.g
thanks for this. Would you mind adding bit of comments to each part describing what the code does.
Best regards,
Sam
@chandra.shekar.g wrote:
@thanh.trantuan,
Firstly, in order to use your code, we have to create new planes which is constraint with existing structures. Could we have another way to do without create new planes like this. As you see, in the skeleton.ipt, these workplanes are created already, so can we use them to position the sketch lines - The same code is modified to get planes from skeleton.ipt
Sub Section_View()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oView As DrawingView
    Set oView = oSheet.DrawingViews.Item(1)
    Dim occ As ComponentOccurrence
    If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
        Dim oComp As AssemblyDocument
        Set oComp = oView.ReferencedDocumentDescriptor.ReferencedDocument
        Set occ = oComp.ComponentDefinition.Occurrences.ItemByName("Skeleton:1")
        Dim oSkeletonDoc As PartDocument
        Set oSkeletonDoc = occ.Definition.Document
    Else
        Exit Sub
    End If
    Dim wpCnt As Integer
    Dim i As Integer
    i = 1
    Dim h As Integer
    h = 1
    Dim v As Integer
    v = 1
    Dim wp As WorkPlane
    For Each wp In oSkeletonDoc.ComponentDefinition.WorkPlanes
        If wp.Name Like "T*" Or wp.Name Like "L*" Then
            Dim oProxy As WorkPlaneProxy
            Call occ.CreateGeometryProxy(wp, oProxy)
            Call oView.SetIncludeStatus(oProxy, True)
            Call oView.SetVisibility(oProxy, False)
            Dim oSketch As DrawingSketch
            Set oSketch = oView.Sketches.Add
            Call oSketch.Edit
            Dim oStartPt As Point2d
            Set oStartPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).StartPoint.X, oSheet.Centerlines.Item(i).StartPoint.Y)
            Dim oStart As Point2d
            Set oStart = oView.SheetToDrawingViewSpace(oStartPt)
            Dim oEndPt As Point2d
            Set oEndPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).EndPoint.X, oSheet.Centerlines.Item(i).EndPoint.Y)
            Dim oEnd As Point2d
            Set oEnd = oView.SheetToDrawingViewSpace(oEndPt)
            Dim oLine As SketchLine
            Set oLine = oSketch.SketchLines.AddByTwoPoints(oStart, oEnd)
            Dim oPt As Point2d
            If oEnd.X = oStart.X Then
                Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width - (10 * v), oView.center.Y)
                Call oSketch.GeometricConstraints.AddVertical(oLine)
                v = v + 1
            Else
                Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(oView.center.X, (10 * h))
                Call oSketch.GeometricConstraints.AddHorizontal(oLine)
                h = h + 1
            End If
            Call oSketch.ExitEdit
            Call oSheet.DrawingViews.AddSectionView(oView, oSketch, oPt, kFromBaseDrawingViewStyle)
            i = i + 1
        End If
    Next
End Sub
Secondly, can we constraint these sketches after creating them - Yes, it constrained to vertical or horizontal.
Thirdly, in the section properties, the section depth is full, could it be set up with the distance (such as 50 mm or 100mm) to show the section at this area only. - Hoping the same answer to Geroge will help this.
Thanks and regards,
