chandra.shekar.g
in reply to: GeorgK
@GeorgK,
At below code, extension of lines can be added depends on line type (Like Horizontal or Vertical).
Dim oStartPt As Point2d
        Set oStartPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).StartPoint.X, oSheet.Centerlines.Item(i).StartPoint.Y)
        Dim oStart As Point2d
        Set oStart = oView.SheetToDrawingViewSpace(oStartPt)
        Dim oEndPt As Point2d
        Set oEndPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).EndPoint.X, oSheet.Centerlines.Item(i).EndPoint.Y)
        Dim oEnd As Point2d
        Set oEnd = oView.SheetToDrawingViewSpace(oEndPt)
        Dim oLine As SketchLine
        Set oLine = oSketch.SketchLines.AddByTwoPoints(oStart, oEnd)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
