03-02-2020
11:48 PM
- Mute
- Permalink
- Report
03-02-2020
11:48 PM
Many thanks your reply and it's highly appreciate your great support I have some questions, could you share your thought
Firstly, in order to use your code, we have to create new planes which is constraint with existing structures. Could we have another way to do without create new planes like this. As you see, in the skeleton.ipt, these workplanes are created already, so can we use them to position the sketch lines
Secondly, can we constraint these sketches after creating them
Thirdly, in the section properties, the section depth is full, could it be set up with the distance (such as 50 mm or 100mm) to show the section at this area only.
Thanks & Best Regards
