chandra.shekar.g
in reply to: oleN2RXT
@oleN2RXT,
Hoping that below idea may be helpful in your case.
Organize your iLogic component files so that the standard models are outside of the folder of the assembly to be placed as an iLogic component. You can store them in a Content Center folder or another Library folder. When you place the assembly as an iLogic component, these files are not copied to the folder of the main assembly. The iLogic component in the assembly maintains its links to the original files, in their original locations.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
