Curtis_Waguespack
in reply to: william
Hi @william
This should work for you.
Also recall that there is the Inventor Customization forum , where programming questions of this type are better suited:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll ask the moderators to move this to that forum.
I hope this helps.
Curtis
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim searchTerm As String
searchTerm = "Item"
For Each oProp In oCustomPropertySet
	If oProp.name.Contains(searchTerm) Then
		MessageBox.Show("We found: " & oProp.name  _
		& vbLf & "Now we're going to delete it!", "iLogic")
		oProp.delete
	End If
Next
