02-20-2020
02:26 PM
- Mute
- Permalink
- Report
02-20-2020
02:26 PM
Hello @johnsonshiue
I have just tried that, I get the same error.
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties") Dim oCustomPropertyName As String oCustomPropertyName = CStr(oCustomPropertySet.Name) Dim searchTerm as String searchTerm = "Item" For Each oCustomPropertyName In oCustomPropertySet If InStr(1, oCustomPropertyName, searchTerm, CompareMethod.Text) >0 Then MessageBox.Show("We found it", "Debug") Else MessageBox.Show("We didnt find it", "Debug") End If Next
Is the InStr command the best way of going about this? I originally took @Curtis_Waguespack code from an earlier post (https://forums.autodesk.com/t5/inventor-forum/how-to-remove-custom-iproperty-with-ilogic/td-p/436406...)
but the ".contains" method doesnt seem to work if the search term is inside the string, eg. it will not pick up that "Item" is contained inside "Item8_Code"
so I found another post that I though would be applicable (https://forums.autodesk.com/t5/inventor-customization/code-vb-for-if-quot-value-quot-contains-quot-t...)
Any help would be appreciated.
