william
901 Views, 4 Replies
I-Logic delete iproperties if they contain a text string
Hello
I am trying to write some code to look through the custom i-properties and if the name of the i-property contains the search term, then delete it.
So far I have got to here...
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
oCustomPropertyName = (oCustomPropertySet.Name)
Dim searchTerm As String
searchTerm = "Item"
For Each oCustomPropertyName in oCustomPropertySet
	If InStr(1, oCustomPropertyName, searchTerm, CompareMethod.Text) >0 Then
		MessageBox.Show("We found it", "Debug")
	Else
		MessageBox.Show("We didnt find it", "Debug")
	End If
Next
The error i am getting is "Conversion from type 'Property' to type 'String' is not valid."
What am I doing wrong?
Regards
