fullevent
in reply to: gcoombridge
Hello @Anonymous,
I have adapted the code of my two previous ones @WCrihfield and @gcoombridge and created this code snippet (VBA).
Sub Hole_throuh_all_Bodies()
    Dim oCD As PartComponentDefinition
    Set oCD = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oSketch As PlanarSketch
    Set oSketch = oCD.Sketches.Item("Skizze4")
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    Dim oED As ExtrudeDefinition
    Set oED = oCD.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kCutOperation)
    Call oED.SetDistanceExtent("1000 mm", kNegativeExtentDirection)
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCD.Features.ExtrudeFeatures.add(oED)
    Dim objCol1 As ObjectCollection
    Set objCol1 = ThisApplication.TransientObjects.CreateObjectCollection
    For Each oExtrude In oCD.Features.ExtrudeFeatures
        If oExtrude.Definition.Operation = kNewBodyOperation Then
            objCol1.add (oExtrude.Definition.AffectedBodies.Item(1))
        ElseIf oExtrude.Definition.Operation = kCutOperation Then
            oExtrude.SetAffectedBodies objCol1
        End If
    Next oExtrude
End Sub
my part bevor running the macro:
and after macro:
I hope it helps you. Maybe you can adapt it to your needs.
Aleks
Aleksandar Krstic
Produkt- und Projektmanager
