fullevent
Basically you want to reorient the solid, right? I've never realized that before. Unfortunately I do not know how this should work or if it is even that easy to do.
But the problem you will have is the following.
Suppose you put the part into many assemblies. Later you change the orientation of the solid body within the IPT.
Then none of your previously created assemblies will fit because the part is suddenly aligned differently.
It would be better to reorient the part within the assembly in which it is placed.
Would that be a possible solution for you?
Aleksandar Krstic
Produkt- und Projektmanager
