02-13-2020
04:33 AM
- Mute
- Permalink
- Report
02-13-2020
04:33 AM
I solved this a while ago and forgot to come back here to post my findings. Below is the code that I put together which has the added benefit of exporting to csv instead of excel so excel doesn't need to be installed on the machine and it prompts for the files to be exported and the csv file to export them to.
Imports System.IO
' Declare the Application object
Dim oApplication As Inventor.Application
' Obtain the Inventor Application object.
' This assumes Inventor is already running.
oApplication = GetObject(, "Inventor.Application")
' FOLDER selection dialog
Dim FilePATH As String = "FilePATH"
Dim dialog As New System.Windows.Forms.FolderBrowserDialog()
dialog.SelectedPath = "R:\Drawings"
dialog.Description = "Select Folder to Pull Drawing Properties From (recursive)"
If dialog.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
drawingDir = dialog.SelectedPath
Else
MsgBox("canceled!")
End If
' FILE Selection dialog
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
End If
'Dim drawingDir = "R:\Drawings"
For Each foundFile As String In My.Computer.FileSystem.GetFiles(drawingDir, FileIO.SearchOption.SearchAllSubDirectories, "*.idw")
ThisDoc.Launch(foundFile)
' Set a reference to the active document.
' This assumes a document is open.
Dim oDoc As Document
oDoc = oApplication.ActiveDocument
' Obtain the PropertySets collection object
Dim oPropsets As PropertySets
oPropsets = oDoc.PropertySets
PartNo = oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kPartNumberDesignTrackingProperties).Value
Revision = oPropsets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").ItemByPropId(kRevisionSummaryInformation).Value
Description = oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kDescriptionDesignTrackingProperties).Value
'Write data info To CSV File
Dim oAppend As System.IO.StreamWriter
'selectedfile = "C:\Users\mraymond\Documents\drawings-local\test\inv-master.csv"
oAppend = IO.File.AppendText(selectedfile)
oAppend.WriteLine(PartNo & "," & Revision & "," & Chr(34) & Description & Chr(34))
oAppend.Flush()
oAppend.Close()
ThisApplication.Documents.CloseAll()
Next
