I have not fund an code that work jet .. but I have fund some of the problem with the code
first of all
GoExcel.CellValue(excel_file, "Sheet1", "A" & i) = iProperties.Value("Project", "Part Number")
it does not read the properties on the that you are open .. with the ilogic code .. but the properties on the file that you open to run the file ... but the code do run on my computer and work it does just not read the properties form the right fil.
second thing
the code fail if excel are not close ... you might have to close all the excel in the joblist
3rd.
It look like it also fail if the cell are not emtry when you start the code.... I am not 100 % sure of this  because it might just have been an Excel program that i have not fund and close..
I use this code to do what your want .. just to open all drawing form an assambly ... maybe you can find a way to rewrite this .. I do not know how at det time and I have to go to bed now... I might look at it again later if i get the time
oRefDocs = oAsmDoc.AllReferencedDocuments
'Dim oRefDoc As Document
cell = 2
For Each oRefDoc In oRefDocs
	cell = cell+1
    idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) -3) & "idw"
	debug(idwPathName.ToString & " " & "NewDrawning")
	'GoExcel.Open(ExcelPath, ExcelSheet)
	'GoExcel.CellValue(ExcelPath, ExcelSheet, "B" + Cell.ToString) = idwPathName
    ' Check to see that the model has a drawing of the same path and name
	Dim oDrawDoc As DrawingDocument
		'False Grafik off True Grafik on
		'MessageBox.Show(idwPathName, "Title")
		Try
        oDrawDoc = ThisApplication.Documents.Open(idwPathName, False)
		Catch
				ExcelPath  = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\PDFLOg.xlsx"
	ExcelSheet = "Log"
	GoExcel.CellValue(ExcelPath, ExcelSheet, "B" + cell.ToString) = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName))
	'GoExcel.CellValue(ExcelPath, ExcelSheet, "B" + cell.ToString) = idwPathName
	Try
	GoExcel.CellValue(ExcelPath, ExcelSheet, "C" + cell.ToString) =  iProperties.Value(oRefDoc.DisplayName, "Project", "Description")
	GoExcel.CellValue(ExcelPath, ExcelSheet, "D" + cell.ToString) = iProperties.Value(oRefDoc.DisplayName, "Custom", "Part Description")
	Catch
		oRefDoc.DisplayName=""
	Try
	Catch
	end try
		debug("wrong displaynName " & idwPathName.ToString)
	End Try
	GoExcel.Save
	'GoExcel.Close
		End Try
    If (System.IO.File.Exists(idwPathName)) Then
		ThisApplication.Documents.Open(idwPathName, True)
		Dim auto = iLogicVb.Automation
	auto.RunExternalRule(oDrawDoc, "SavePDF")
		oDrawDoc.Close
		oDrawDoc.Close
	ExcelSheet = "Log"
	GoExcel.Save
	GoExcel.Close
