mraymond7REU2
3823 Views, 15 Replies
Iproperties Export to Excel
Hi, I am trying to export the iproperties of all the drawings in our drawing folder to an excel sheet, is there an existing way to do this? I have put together an ilogic script from a bunch of other posts but I cant get it to work, I frequently get this error, Unspecified error (Exception from HRESULT: 0X80004005 (E_FAIL)). Any help would be much appreciated.
Sub Main()
	'declare variable for inventory master excel file
	excel_file = "C:\Users\mraymond\Documents\inventory-master.xlsx"
	'open excel file
	GoExcel.Open(excel_file, "Sheet1")
	'Create folder variable and Select folder with drawings in it
	Dim Folder As New IO.DirectoryInfo("C:\Users\mraymond\Documents\R-Drive Copy\test\")
	'Create file list variable that will contain list of files in string format
	Dim FileList As New List(Of String)
	'for loop that will loop through each file found in folder variable and add to file list
	For Each File As IO.FileInfo In Folder.GetFiles("*.idw",IO.SearchOption.AllDirectories)
	    If File.FullName.Contains("OldVersions") = False Then
	        FileList.Add(File.FullName)
	    End If
	Next
	'display count of files found in folder
	MsgBox(FileList.Count & " Files were found!")
	'create variable for document
	Dim oDoc As Document
	'for loop that goes through file on the file list variable
	For Each DocName As String In FileList
	    oDoc = ThisApplication.Documents.Open(DocName, True)
		'for loop to find the first empty row in the inventory master excel file
		Dim i As Integer
		For i = 2 To 20000
		'find first empty cell in column A
			If (GoExcel.CellValue("A" & i) = "") Then
				'this command will run on each document in the folder variable
				GoExcel.CellValue(excel_file, "Sheet1", "A" & i) = iProperties.Value("Project", "Part Number")
				GoExcel.CellValue(excel_file, "Sheet1", "B" & i) = iProperties.Value("Project", "Revision Number")
				GoExcel.CellValue(excel_file, "Sheet1", "C" & i) = iProperties.Value("Project", "Description")
				Exit For
			Else
				i = + 1
			End If
		Next
	    oDoc.Close
	Next
	GoExcel.Save
	GoExcel.Close
End Sub
