- Mute
- Permalink
- Report
I need to format the Thickness, Width, and Length parameters on a group of parts from the assembly level.
I know this has been done, and I found what I though were many solutions, none of which worked. At least I was able to screw it up. I'm finally at a point it looks like the rule is running, but nothing is changing.
I need to verify the rule is running only on parts that are modifiable. I'd also like the rule to run if is executed in a part file.
I've attached my latest failure.
Inventor Pro 2023
Vault Pro 2023
- Mute
- Permalink
- Report
What would you exactly like to do?
Could you explain it step by step?
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
I believe this is working as you want, not too different from what you posted:
Sub Main
If ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Or ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then Else Exit Sub
Dim openDoc As Document = ThisApplication.ActiveDocument
'Look at all of the files referenced in the open document
Dim docFile As Document
If openDoc.DocumentType = kPartDocumentObject
Call Formatting(openDoc)
Else
For Each docFile In openDoc.AllReferencedDocuments
'look at only part files that are modifiable
If docFile.DocumentType = kPartDocumentObject And docFile.IsModifiable = True
Call Formatting(docFile)
End If
Next
End If
iLogicVb.UpdateWhenDone = True
End Sub
Sub Formatting(oDoc As PartDocument)
'For Thickness Parameter
Try
oThickness = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Thickness")
Catch
oThickness = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Thickness", 1, "in")
End Try
oThickness.ExposedAsProperty = True
If oThickness.Units = "mm"
oFormat=oThickness.CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
oFormat.Units = "mm"
oFormat.ShowUnitsString = True
oFormat.ShowLeadingZeros = False
oFormat.ShowTrailingZeros = True
Else If oThickness.Units = "in"
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
oFormat.Units = "in"
oFormat.ShowUnitsString = False
End If
'] For Thickness Parameter
'For Width Parameter
Try
oWidth = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Width")
Catch
oWidth = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Width", 15, "in")
End Try
oWidth.ExposedAsProperty = True
If oWidth.Units = "mm"
oFormat=oWidth.CustomPropertyFormat
Else If oWidth.Units = "in"
End If
'] For Width Parameter
'For Length Parameter
Try
oLength = oDoc.ComponentDefinition.Parameters.UserParameters.Item("Length")
Catch
oLength = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Length", 45, "in")
End Try
oLength.ExposedAsProperty = True
If oLength.Units = "mm"
oFormat=oLength.CustomPropertyFormat
Else If oLength.Units = "in"
End If
'] For Length Parameter
oDoc.Rebuild
End SubI put the formatting into a subroutine to make handling the different document types easier in the main routine.
- Mute
- Permalink
- Report
The rule would format the exported Thickness, Width, and Length parameters based on the parameters units, "in" or "mm".
For example:
If oThickness.Units = "mm" Then oFormat=oThickness.CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision oFormat.Units = "mm" oFormat.ShowUnitsString = True oFormat.ShowLeadingZeros = False oFormat.ShowTrailingZeros = True Else If oThickness.Units = "in" Then oFormat=oThickness.CustomPropertyFormat oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision oFormat.Units = "in" oFormat.ShowUnitsString = False oFormat.ShowLeadingZeros = False oFormat.ShowTrailingZeros = True
If the rule runs in a part file the parameters would be formatted as shown based on the units.
If the rule runs in an assembly file, the parameters in all the parts would be formatted.
If the part is modifiable.
Inventor Pro 2023
Vault Pro 2023
- Mute
- Permalink
- Report
That is almost exactly what I need.
The thing I didn't account for is, in some files the parameters may not be user parameters. Sometimes they can be model parameters. In those cases the rule recreates the parameter as a user parameter and the intended parameter doesn't get formatted.
For example if "Thickness" is a model parameter it won't be formatted, and "Thickness_1" will be created and formatted as a user parameter.
How can it be written to format the existing model parameter and not recreate it?
Inventor Pro 2023
Vault Pro 2023
- Mute
- Permalink
- Report
You should be able to change the Trys to be less specific and look through all Parameters instead of all User Parameters:
Sub Main
Else
End If
Next
End If
End Sub
Try
oThickness = oDoc.ComponentDefinition.Parameters.Item("Thickness")
Catch
End Try
End If
Try
oWidth = oDoc.ComponentDefinition.Parameters.Item("Width")
Catch
End Try
End If
Try
oLength = oDoc.ComponentDefinition.Parameters.Item("Length")
Catch
End Try
End If
oDoc.Rebuild
End Sub
