377 Views, 1 Reply
Create Leader Note with the properties model- part number
Hi, i was trying to create an automated annotation tag but through ilogic but this is what i have so far..
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim s As String
s = "<StyleOverride Font='Arial'><Parameter Resolved='True' ComponentIdentifier='C:\Users\hanb\Documents\Disc.ipt' Name='HoleQuantity' Precision='0'>8</Parameter></StyleOverride><StyleOverride Font='Arial'> HOLES ON DIA </StyleOverride><StyleOverride Font='Arial'><Parameter Resolved='True' ComponentIdentifier='C:\Users\hanb\Documents\Disc.ipt' Name='HolePCD' Precision='0'>35</Parameter></StyleOverride><StyleOverride Font='Arial'>±0.1 </StyleOverride><Br/><StyleOverride Font='Arial'>WITH </StyleOverride><StyleOverride Font='Arial'><Parameter Resolved='True' ComponentIdentifier='C:\Users\hanb\Documents\Disc.ipt' Name='HoleQuantity' Precision='0'>8</Parameter></StyleOverride><StyleOverride Font='Arial'> DIVISIONS</StyleOverride>"
Dim curve As DrawingCurve
curve = oDoc.SelectSet.Item(1).Parent
Dim oGI1 As GeometryIntent
oGI1 = oDoc.ActiveSheet.CreateGeometryIntent(curve, kCenterPointIntent)
Dim pt As Point2d
pt = ThisApplication.TransientGeometry.CreatePoint2d
pt.X = curve.CenterPoint.X + 3
pt.Y = curve.CenterPoint.Y + 5
Dim oObjCol As ObjectCollection
oObjCol = ThisApplication.TransientObjects.CreateObjectCollection
oObjCol.Addpt
oObjCol.AddoGI1
Dim oLN As LeaderNote
' create a LeaderNote.
oLN = oDoc.ActiveSheet.DrawingNotes.LeaderNotes.Add(oObjCol, "")
oLN.FormattedText = s
JelteDeJong
i changed your code a bit. try this:
Dim s As String
s = "<Property Document='model' PropertySet='Design Tracking Properties' Property='Appearance' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='72'>APPEARANCE</Property>"
oGI1 = oDoc.ActiveSheet.CreateGeometryIntent(curve, PointIntentEnum.kCenterPointIntent)
Dim pt As Point2d
pt.X = oGI1.PointOnSheet.X + 3
pt.Y = oGI1.PointOnSheet.Y + 3
oObjCol.Add(pt)
oObjCol.Add(oGI1)
oLN = oDoc.ActiveSheet.DrawingNotes.LeaderNotes.Add(oObjCol, "efadva")
i did have some with your formated string. so i changed it to show the Appearance iProperty. You probaly need something else. there for this rule that will shows the formated string of an leader that you need to select.
Dim test As LeaderNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingNoteFilter, "")
MsgBox(test.FormattedText)
Jelte de Jong
Blog: hjalte.nl - github.com
