mcgyvr
in reply to: Curtis_Waguespack
In the code provided by Curtis (that caused the error for you)...
If the color you want isn't "Dark Green" replace that in the code with whatever appearance name you want to use. Just spell it exactly as it is in the library.  In your case that might be "Green (Clear)" or whatever local appearance you want applied to that face.. Curtis just used "Deep Green" as an example.. Change as needed..
oFace.Appearance = oDoc.Assets.Item("Green (Clear)")
