01-27-2020
01:47 PM
- Mute
- Permalink
- Report
01-27-2020
01:47 PM
try this:
Dim doc As PartDocument = ThisDoc.Document
Dim face As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "")
Dim camera As Camera = ThisApplication.ActiveView.Camera
'get the midpoint param from selected surface
Dim paramRangeRect As Box2d = face.Evaluator.ParamRangeRect
Dim params(1) As Double
params(0) = (paramRangeRect.MaxPoint.X + paramRangeRect.MinPoint.X) / 2
params(1) = (paramRangeRect.MaxPoint.Y + paramRangeRect.MinPoint.Y) / 2
'get point on surface at param
Dim points(2) As Double
face.Evaluator.GetPointAtParam(params, points)
Dim target As Point = ThisApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2))
' next line is only for debug to show what the camera target is
doc.ComponentDefinition.WorkPoints.AddFixed(target)
camera.Target = target
'get the normal of the surface at target point
'translate target point with normal-vector to eye point
Dim normals(2) As Double
face.Evaluator.GetNormal(params, normals)
Dim normal As Vector = ThisApplication.TransientGeometry.CreateVector(normals(0), normals(1), normals(2))
Dim eye As Point = target
eye.TranslateBy(normal)
' next line is only for debug to show what the camera eye is
doc.ComponentDefinition.WorkPoints.AddFixed(eye)
camera.Eye = eye
'you might want to set also the upvector to rotate the view to something more sensible.
'but i dont know how....
'camera.UpVector = ???
camera.ApplyWithoutTransition()
' i tryed to soom to selected surface with the camera but did not manage
' therefor this hack
doc.SelectSet.Clear()
doc.SelectSet.Select(face)
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomSelectCmd").Execute()
Jelte de Jong
Blog: hjalte.nl - github.com
