jfenter
in reply to: JhoelForshav
My initial test of the suggested solution seems to be working, but I found an error in the rules that set the iProperties that is causing a "no" result when it should be a "yes".  Unfortunately I've been forced into temporarily changing projects so I have to sit on this until I can continue debugging the rules.
