Hillebrand
526 Views, 2 Replies
Get Tolerance for HoleThreadNote
I need some help.
I want to collect all tolerances used in a drawing view.
Collecting the drawing tolerances for DrawingDimensions works fine. But it is a problem to get the tolerances defined for  holefeatures in parts model.
   HoleThreadNote first = sheet.DrawingNotes.HoleThreadNotes.Cast<HoleThreadNote> ().First ();
   string a = first.Text.Text;
   // a = "n3,00 H7 DURCH"
   string holTol = first.Tolerance.HoleTolerance;
   // holTol = "";
   string shaftTol = first.Tolerance.ShaftTolerance;
   // shaftTol = "";
Is there another method to get the "model" tolerances? Only possible by parsing the text string?
Thank you!
Regards
Petra
HideoYamada
in reply to: Hillebrand
This code get Tolerance object that is corresponding to HoleThreadNote.
Sub test()
    Dim oSheet As Sheet
    Set oSheet = ThisApplication.ActiveDocument.ActiveSheet
    Dim oHoleThreadNote As HoleThreadNote
    Set oHoleThreadNote = oSheet.DrawingNotes.HoleThreadNotes(1)
    Dim oFace As Face
    For Each oFace In oHoleThreadNote.Intent.Geometry.ModelGeometry.Faces
        If TypeOf oFace.CreatedByFeature Is HoleFeature Then
            Dim oHoleFeature As HoleFeature
            Set oHoleFeature = oFace.CreatedByFeature
            Dim oTolerance As Tolerance
            Set oTolerance = oHoleFeature.HoleDiameter.Tolerance
            Debug.Print oTolerance.HoleTolerance
            Exit For
        End If
    Next oFace
End Sub
oHoleThreadNote.Intent.Geometry.ModelGeometry is pointing the edge in the part model.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Hillebrand
in reply to: HideoYamada
Works perfect!
Thank you so much!
