- Mute
- Permalink
- Report
There are multiple ways to get that information into the Custom iProperties.
- You could manually enter it within that Custom tab of the iProperties
- If the value you want is already a Parameter in your Fx Parameters dialog box, then within the Parameters dialog box, you could click on the Export Parameter checkbox in its row. This automatically copies it to the Custom iProperties.
- You could use an iLogic rule to transfer that data to the Custom iProperties
Can you please be more informational as to what you need?
Wesley Crihfield
(Not an Autodesk Employee)
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Would this work for you then?
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCustPropSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Part Face.")
Dim oMeasure As MeasureTools
Dim oTLL As Double = oMeasure.GetLoopLength(oFace.Edges) 'oTLL is short for Total Loop Length
Dim oTLL_Prop As [Property] = oCustPropSet.Add(oTLL,"Total Loop Length")If this solves your problem, please "Accept As Solution".
Or if it helps you along the way to achieving your goal, please click "Like".
Wesley Crihfield
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Perhaps if I added a MessageBox question, and a check for that iProperty at the end like this.
oAnswer = MessageBox.Show("Total Loop Length = " & oTLL & vbNewLine &
"Do you want To write this value To iProperties ? ", " TOTAL Loop LENGTH ", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
If oAnswer = vbNo Then
Return
ElseIf oAnswer = vbYes Then
'The following checks to see if that iProperty already exists.
'In case you have already ran this rule before on the same document.
Dim oExists As Boolean = False
For Each oProp As [Property] In oCustPropSet
If oProp.Name = "Total Loop Length" Then
oExists = True
End If
Next
If oExists = False Then
oCustPropSet.Add(oTLL, "Total Loop Length")
ElseIf oExists = True Then
oCustPropSet.Item("Total Loop Length").Value = oTLL
End If
End IfDoes this work for you?
If this solves your problem, please click 'Accept As Solution'.
Or if this helps you along the way to reaching your goal, please click the 'Like' button. ![]()
Wesley Crihfield
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Sorry about that. My mistake. I didn't properly define the MeasureTools. I left out the "= ThisApplication.MeasureTools" at the end of that line. I didn't take the time to test the code before posting it last time.
Here's the working version.
Dim oMeasure As MeasureTools = ThisApplication.MeasureTools
Dim oTLL As Double
oTLL = oMeasure.GetLoopLength(oFace.EdgeLoops.Item(1)) 'oTLL is short for Total Loop Length
"Do you want To write this value To iProperties ? ", " TOTAL LOOP LENGTH ", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
Return
oExists = True
End If
Next
End If
End If
Wesley Crihfield
- Mute
- Permalink
- Report
Sorry, I didn't work, when the value appears on the custom iproperties the value was wrong.
- Mute
- Permalink
- Report
You may need to convert the value to your local document units. By default, any Double type values that are returned from iLogic's built-in measurement functions, are always given in the "Database Units" for that type of measurement. The "Database Units" used for Length measurements is always Centimeters, instead of the units specified within the Document Settings. That's just how iLogic is set up, and that can't be changed. However, you can convert the returned values by which ever means you prefer. You can simply include some extra math in your code to compensate for the unit differences, or you can use Inventor's built-in unit converter.
Here is an updated version of that code, in which I am converting the units to Inches, instead of leaving them in default Centimeters. I've also included the Perimeter measurement, to show the difference (when applicable).
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kPartDocumentObject Then
MsgBox("A Part Document must be active for this rule to work. Exiting.", vbOKOnly + vbCritical, "WRONG DOCUMENT TYPE")
Exit Sub
End If
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCustPropSet As PropertySet = oPDoc.PropertySets.Item("Inventor User Defined Properties")
Dim oPerimeter, oOther, oTLL As Double
For Each oEL As EdgeLoop In oFace.EdgeLoops
If oEL.IsOuterEdgeLoop Then
'<<< This doesn't accound for interior holes or cutouts >>>
oPerimeter = oMeasure.GetLoopLength(oEL)
Else
oOther = oOther + oMeasure.GetLoopLength(oEL)
End If
Next
oTLL = (oPerimeter + oOther)
'Convert the Database Units (Centimeters) to Inches
'oPerimeter = (oPerimeter / 2.54)
'oOther = (oOther / 2.54)
'or
oPerimeter = ThisApplication.UnitsOfMeasure.ConvertUnits(oPerimeter, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
oOther = ThisApplication.UnitsOfMeasure.ConvertUnits(oOther, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kInchLengthUnits)
'the measured units have already been converted now, so the math with be in Inches
oAns = MsgBox("Perimiter = " & oPerimeter & vbCrLf & _
"Other Interior Loop Lengths = " & oOther & vbCrLf & _
"Total Loop Length = " & oTLL & vbCrLf & _
"Do you want to write the Total Loop Length value to iProperties? ", vbYesNo + vbQuestion + vbDefaultButton2, " TOTAL LOOP LENGTH ")
If oAns = vbNo Then
Exit Sub
ElseIf oAns = vbYes Then
'checking if that iProperty already exists or if it needs to be created
Dim oExists As Boolean 'False by default
For Each oProp As Inventor.Property In oCustPropSet
oProp.Value = oTLL
oExists = True
End If
Next
End If
End If
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE'
If you have time, please... Vote For My IDEAS
and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
