Hi, have you tried setting up the printer you need from "Print Setup"?
Through ilogic code you could do it through
Dim oDoc As DrawingDocument = ThisDoc.Document
'View the current printer
MessageBox.Show(oDoc.PrintManager.Printer)
'Set type of printer
oDoc.PrintManager.Printer = "Fax"
By executing that segment of code in a drawing file you can get / set the type of printer you want
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
