628 Views, 7 Replies
Can't set kPrintColorPalette, DrawingPrintManager
I'm having trouble setting the ColorMode for DrawingPrintManager.
 Setting the ColorMode to kPrintGrayScale and kPrintDefaultColorMode works fine, the problem is when I'm trying to set the ColorMode to kPrintColorPalette nothing happens. By some strange reason it will always be set to kPrintDefaultColorMode?!? (The AllColorsAsBlack setting is false)
        private void PrintDrawing(Application application)
            var document = (DrawingDocument)application.ActiveDocument;
            var printManager = (DrawingPrintManager)document.PrintManager;
            // Printer
            printManager.Printer = PrinterSettings.printer;
            // Papersize
            printManager.PaperSize = PrinterSettings.paperSize;
            if (printManager.PaperSize == PaperSizeEnum.kPaperSizeCustom)
                printManager.PaperHeight = PrinterSettings.customHeight;
                printManager.PaperWidth = PrinterSettings.customWidth;
            // Orientation
            printManager.Orientation = PrinterSettings.orientation;
            // Color
            printManager.ColorMode = PrinterSettings.color;
            printManager.AllColorsAsBlack = PrinterSettings.allColorsBlack;
            // Range
            printManager.PrintRange = PrinterSettings.whatToPlot;
            // Copies
            printManager.NumberOfCopies = PrinterSettings.numberOfCopies;
            // Scale
            printManager.ScaleMode = PrinterSettings.scale;
            printManager.Scale = PrinterSettings.customScale;
            // Misc
            printManager.TilingEnabled = PrinterSettings.tiling;
            printManager.RemoveLineWeights = PrinterSettings.lineWeights;
            printManager.SubmitPrint();
