- Mute
- Permalink
- Report
Thanks all but I got my ilogic code working which add custom iproperty to assembly and all parts in that assembly, so that in BOM when you add that custom iproperties to the table, all parts/subasys have the information you want.
Here is the code, if someone also looking for it like i was:
Dim asmDoc As AssemblyDocument = ThisDoc.Document
iProperties.Value(Model, "Custom", "ABAS PN") = iProperties.Value(Model, "Project", "Part Number") &"-"& iProperties.Value(Model, "Project", "Revision Number")
Dim childDoc As Document
For Each childDoc In asmDoc.AllReferencedDocuments
Try
Dim filename = IO.Path.GetFileName(childDoc.FullFileName)
iProperties.Value(filename, "Custom", "ABAS PN") = iProperties.Value(filename, "Project", "Part Number") &"-"& iProperties.Value(filename, "Project", "Revision Number")
Catch
End Try
Next
If this answer your question, please give it a "KUDOS"
