12-11-2019
08:08 AM
- Mute
- Permalink
- Report
12-11-2019
08:08 AM
Using iLogic, I'm not seeing any easy way to actually 'delete' a cell in an Excel file. Nor be able to set which option to use for either shifting the other cells, Entire Row, or Entire Column, after you delete it, as you have within Excel.
I see a method to 'Clear' its value, though, if that's all you need.
You would most likely have to do this using Inventors API and VBA code with the VBA Editor, once you've included the right "References" for working with Microsoft Excel.
Wesley Crihfield
(Not an Autodesk Employee)
