Thanks for your code, you mean by "Part1" is the name of the occurrence in the design tree or the name of the file in the project directory?
I am trying to refer to specific ( part, occurrence) in the assembly automatically not by selecting its item number from the Watch window but rather to search for that occurrence for me  ( see my new code)
Sub ADDHingeDimension()
' refer to the file
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' refer to the sheet
Dim oSheet As Sheet
Set oSheet = oDrawDoc.Sheets.Item(1)
'refer to the View
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
'refer to refrenced Assembly
Dim oAssembly As AssemblyDocument
Set oAssembly = oView.ReferencedDocumentDescriptor.ReferencedDocument
'refer the the Model in the Assembly
Dim i As Integer
For i = 1 To oAssembly.AllReferencedDocuments.Count
Dim oModelDoc As Document
Set oModelDoc = oAssembly.ReferencedDocuments.Item(i)
'refer to the Edge on the Model
If oModelDoc.DisplayName = "Hopper_InspectionDoor_cover.ipt" Then
Dim Edge2 As Edge
Set Edge2 = oModelDoc.AttributeManager.FindObjects("*", "*", "Door_Left").Item(1)
Exit For
ElseIf oModelDoc.DisplayName = "Hopper_InspectionDoor_Plate.ipt" Then
Dim Edge1 As Edge
Set Edge1 = oModelDoc.AttributeManager.FindObjects("*", "*", "Plate_Type1_Left").Item(1)
End If
Next
' refer to occurrance in the assembly
Dim j As Integer
For j = 1 To oAssembly.ComponentDefinition.Occurrences.Count
Dim oOcc As ComponentOccurrence
Dim oOcc1 As ComponentOccurrence
Dim oOcc2 As ComponentOccurrence
Set oOcc = oAssembly.ComponentDefinition.Occurrences.Item(j)
If oOcc.Name = "Hopper_InspectionDoor_Door:1" Then
Set oOcc2 = oAssembly.ComponentDefinition.Occurrences.Item(j)
ElseIf oOcc.Name = "Hopper_InspectionDoor_Plate:2" Then
Set oOcc1 = oAssembly.ComponentDefinition.Occurrences.Item(j)
Exit For
End If
Next
' promot edge to proxy
Dim oproxy1 As EdgeProxy
  Call oOcc1.CreateGeometryProxy(Edge1, oproxy1)
Dim oproxy2 As EdgeProxy
  Call oOcc2.CreateGeometryProxy(Edge2, oproxy2)
 ' promot proxy to Drawing curve
 Dim oCurve1 As DrawingCurve
 Set oCurve1 = oView.DrawingCurves(oproxy1).Item(1)
 Dim oCurve2 As DrawingCurve
 Set oCurve2 = oView.DrawingCurves(oproxy2).Item(1)
of course, my code is incomplete and the last line introduces error to me I do not why, in the Watch Window,  the Variable called "oView.DrawingCurves(oproxy2)" contains no items  see below
  what I really like to do is to place a dimension between two different parts in the assembly ( inspection door)
see this view below
