mostafamahmoudseddek94
598 Views, 5 Replies
help with modifying my code
Hi, the problem that I face is to have an automated Assembly Drawings for the master assembly that I made in which there are a lot of configurations for it. (bag filter)
Dimensions that specifying -for example- the stiffeners spacing is deleted when I configure the master assembly to a different one.
I used the attribute to name the edges of a part in the assembly and I have written a code to add the dimension that I need on the assembly Drawing, the code works fine but I need to modify it so instead of specifying the number of the wanted item " item(1) for example" I would like to input the name of the item and the code  search and  return the item number, this because when I configure the master assembly, the number of the wanted item is changed and its occurrence item number is also changed.
Sub CreatAssemblyDim()
' refer to the file
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'refer to the active sheet
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
'refer to the view
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(1)
'refer to the assembly on the view
Dim oAssembly As AssemblyDocument
Set oAssembly = oView.ReferencedDocumentDescriptor.ReferencedDocument
'find the model referenced  in the assembly
'Dim i As Integer
'For i = 1 To oAssembly.ReferencedDocuments.Count
Dim oModelDoc As Document
Set oModelDoc = oAssembly.ReferencedDocuments.Item(2)
' refer to the edge
Dim Edge1 As Edge
'MsgBox (oModelDoc.DisplayName)
Set Edge1 = oModelDoc.AttributeManager.FindObjects("*", "*", "Left").Item(1)
Dim Edge2 As Edge
Set Edge2 = oModelDoc.AttributeManager.FindObjects("*", "*", "Right").Item(1)
'Next
' refere to occurrence in the assembly
Dim oCompOcc As ComponentOccurrence
For Each occurrence In oAssembly.ComponentDefinition.Occurrences
'becouse there's only one occurrence
Set oCompOcc = oAssembly.ComponentDefinition.Occurrences.Item(1)
' promote the model edge to the assembly using poroxy
Dim oOccEdge1Proxy As EdgeProxy
Dim oOccEdge2Proxy As EdgeProxy
Call oCompOcc.CreateGeometryProxy(Edge1, oOccEdge1Proxy)
Call oCompOcc.CreateGeometryProxy(Edge2, oOccEdge2Proxy)
Next
'promote to an a DrawingCurve on the view
Dim oDrawingCurves1 As DrawingCurve
Set oDrawingCurves1 = oView.DrawingCurves(oOccEdge1Proxy).Item(1)
Dim oDrawingCurves2 As DrawingCurve
Set oDrawingCurves2 = oView.DrawingCurves(oOccEdge2Proxy).Item(1)
'promote to a geometryIntent on the sheet
Dim GI1 As GeometryIntent
Set GI1 = oSheet.CreateGeometryIntent(oDrawingCurves1)
Dim GI2 As GeometryIntent
Set GI2 = oSheet.CreateGeometryIntent(oDrawingCurves2)
'Create a general Dimension on that shett
Dim oGeneralDims As GeneralDimensions
Set oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
' Create point for the text
Dim TextPoint As Point2d
Dim Xpo As Double
Dim Ypo As Double
Xpo = oView.Left + (oView.Width / 4)
Ypo = oView.Top + 3
Set TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(Xpo, Ypo)
' Create the Dimemsion
Dim oDim1 As GeneralDimension
  Set oDim1 = oGeneralDims.AddLinear(TextPoint, GI1, GI2)
     For Each oDim1 In oGeneralDims
        If oDim1.Attached = False Then
            Call oDim1.Delete
        End If
    Next
End Sub
