cadprof
Thank you for the reply.  I did not make any major changes, but I have pasted the code here.
'Code By @ClintBrown3D
'Originally posted at https://clintbrown.co.uk/automatic-drawings-With-ilogic/
'Check if this is a drawing file
Dim doc = ThisDoc.Document
If doc.DocumentType = kDrawingDocumentObject Then
GoTo DRAWINGcode :
End If
'In parts & asemblies - Write file name and path to temp text file
oWrite = System.IO.File.CreateText("C:\TEMP\part.txt")
oWrite.WriteLine(ThisDoc.PathAndFileName(True))
oWrite.Close()
oFilePather = ThisDoc.Path & "\"
'In parts & asemblies - Write new drawing name to temp text file
oWrite = System.IO.File.CreateText("C:\TEMP\partno.txt")
oWrite.WriteLine(oFilePather & iProperties.Value("Project", "Part Number") & ".idw")
oWrite.Close()
'Read Drawing name from text file
oRead = System.IO.File.OpenText("C:\TEMP\partno.txt")
EntireFile1 = oRead.ReadLine()
oRead.Close()
oDrawingName = EntireFile1
'Copy the Template file > keep templates saved in your project workspace, you need a separate part and assembly template
Dim oCopyFiler As String = "ANDRITZ USA"
If doc.DocumentType = kAssemblyDocumentObject Then
oCopyFiler = "C:\Users\Public\Public Documents\Autodesk\Inventor 2019\Templates\English\Automate-Assy.idw"
Else If doc.DocumentType = kPartDocumentObject Then
oCopyFiler = "C:\Users\Public\Public Documents\Autodesk\Inventor 2019\Templates\English\Automate-Rev.idw"
End If
' Check if drawing exists - If it does, opening existing drawing
If System.IO.File.Exists(oDrawingName & DWGType) Then
MessageBox.Show("Drawing already exists > Opening Existing Drawing", "ANDRITZ USA")
ThisDoc.Launch(oDrawingName & DWGType)
Return
End If
'Launch New drawing
Dim oNewFiler As String = EntireFile1
System.IO.File.Copy(oCopyFiler,oNewFiler,(True))
ThisDoc.Launch(oNewFiler)
DRAWINGcode :
On Error GoTo Exiter
'Check if we have replaced the reference and scaled the drawing already
oNumbero = Parameter("Opened")
Parameter("Opened") = oNumbero + 1
MsgBox(Parameter("Opened"))
If Parameter("Opened") > 2 Then
Return
End If
'Read in File name - For reference
oRead = System.IO.File.OpenText("C:\TEMP\part.txt")
EntireFile = oRead.ReadLine()
oRead.Close()
oPartPath = EntireFile
'Replace Drawing Reference
Dim oFileDesc As FileDescriptor
oFileDesc = doc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFileDesc.ReplaceReference(oPartPath)
doc.Update()
'Read in new name for Drawing
oRead.Close()
'Save this drawing
ThisDoc.Save
'Scale the Drawing - Note your drawing views names("VIEW1")&("VIEW4") must match the template
oMyParameter = ThisDrawing.Document.Parameters.UserParameters
oParameter = oMyParameter.AddByValue("Scaler", "1:5", UnitsTypeEnum.kTextUnits)
MultiValue.SetList("Scaler","1:1", "1:2", "1:4", "1:5", "1:10", "1:20", "1:25", "1:50", "1:100")
Scaler = InputListBox("Set Drawing Scale", MultiValue.List("Scaler"), Scaler, Title := "Scale = " & ActiveSheet.View("VIEW1").ScaleString, ListName := "List")
ActiveSheet.View("VIEW1").ScaleString = Scaler
ActiveSheet.View("VIEW4").ScaleString = Scaler
Parameter.Param("Scaler").Delete
Exiter :
Msgbox("Scale not Changed")
