as soon as you make a multi value parameter, the attribute will also be created for that parameter.
value = 0  : check is off
value = 1   : check is on
when a parameter is not a multi value parameter the attribute does not exist
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
