- Mute
- Permalink
- Report
What do you exactly mean with the first time than?
Can this also be the first time that the rule has not run for this file?
Then I normally create a custom prop as Boolean = false.
I read this and take a look if the rule has run once.
When the rule is fired I write the Boolean = true to that Custom Property.
Arthur Knoors
Autodesk Affiliations:
