11-20-2019
01:19 AM
- Mute
- Permalink
- Report
11-20-2019
01:19 AM
Hey, I had a follow-up question if possible. I understand that .FileSaveCounter is a read-only file but the code you supplied says that as long as the value of .FileSaveCounter is 0, I can't perform the rest of my code. I can't flip it the other way because my file save counter is never 0. Curently it's at 33 or 34, something like that. Do you know a way to edit the code you supplied or perhaps have the counter reset to 0 at the beginning of the code? Here's my bit so far, thank you for your help.
Public Sub Main()
Dim doc = ThisDoc.Document
doc.FileSaveCount = 0
MsgBox(doc.FileSaveCounter)
If doc.FileSaveCounter = 0 Then
Dim modelname As String
Dim odoc As Document
iLogicForm.Show("Save Drawing")
modelname = iProperties.Value("Summary", "Title")
If saved = True Then
ThisDoc.Document.saveasinventordwg("[MACHINE DRAWING FILEPATH]" & modelname & ".dwg", True)
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'get PDF target folder path
oFolder = "[PDF DRAWING FILEPATH]"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & modelname & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
ThisApplication.Documents.Open("[MACHINE DRAWING FILEPATH]" & modelname & ".dwg")
ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop").Execute2(False)
Else
Logger.Debug("saved?: " & saved)
Exit Sub
End If
saved = False
End If
End Sub
